crossovers on a 502 mpi? >
Old 02-13-2004 | 07:31 PM
CAP071's Avatar
Question crossovers on a 502 mpi?
Anyone running a crossover on their 502 Mag/Mpi? does it work ok? Do you run a thermostat?
CAP071 is offline
Old 02-13-2004 | 09:04 PM
marinetrans's Avatar
Hardin Marine makes a crossover kit for 1 piece serpintine belts now. I hear they work good. I think the kit comes w/ thermostat.
marinetrans is offline
Old 02-13-2004 | 09:09 PM
CAP071's Avatar
thanks
http://www.cpperformance.com/detail....ct_id=520-502W
CAP071 is offline
Old 02-13-2004 | 09:39 PM
paradigm shift's Avatar
Default Re: crossovers on a 502 mpi?
You will want to run a thermostat and make sure you get water temperature up. ECM will stay in a cold start mode and run very rich if you don't. It will - can wash down cylinder walls and kill the rings if it runs cold all the time. MAKE sure and check your water pressure if you are not running gauges already. Just my .02. Other than circulating pump being FUGLY and a pain when it leaks the stock set up works pretty well. Crossover is not always just a bolt on go set up like they lead you to believe.
paradigm shift is offline
Old 02-13-2004 | 09:44 PM
CAP071's Avatar
Sooooooooo true.
CAP071 is offline
Old 02-13-2004 | 09:54 PM
Yeah, It turns into a sh**sandwich sometimes.
CAP071's Avatar
Nothing is easy as advertised
CAP071 is offline
27Fountain
Do It Yourself, Boating on a Budget
4
09-08-2008 01:11 AM
cass236
2
07-21-2008 01:00 PM
brian valery
05-18-2007 10:42 AM
brian valery
05-17-2007 04:40 PM
Steve_H
11
02-07-2004 05:57 PM
