500efi Valve Springs, Help??
Registered User
I know this has been covered before, but I feel I need to replace my Valve springs, I have a 2001 500efi w/ 280 hours.
1. Exactly what needs to be replaced, Valve springs, Lifters,??? and what mfg would you replace with, I have been told Isky??
2. Anyone personally suggest a mech in VA ?? to do the work?
All input is really appreciated when it comes to engines
WILL
WILL
Will,
if your interested I have set of NEW ISKY 8005-A springs for that setup.
They are currently on my new heads but I'm upgrading them for a larger cam.
$75 delivered.
Dave
[email protected]
$75 delivered.
Dave
[email protected]
27Fountain,
If you need to find a good shop to do your valve train update, give BK a call at Offshore Performance in MD. We have plenty of certified tech's and can get you done in a timley manner so you wont miss any boating season.
Pwrbt33
1-877-GOFAST1
410-827-0200
Pwrbt33
1-877-GOFAST1
410-827-0200
Time for a new set of lifters if ya ask me. Ever seen a block explode when a lifter roller pin comes loose and hits the bottom of the lifter bore? Not a pretty site at all. And while you're at it, a new set of crane 1.8:1 rocker arms will pick up a bit of power for you.
Originally posted by high-tide
Do a leak down and compression test first. My opinion.
good luck,
High-Tide
good luck,
High-Tide
But it will put your mind at ease about the the shape of your piston rings. Asuming the test is good.
Miss Happ
02-14-2006 09:04 PM
BAJA WILL
04-10-2003 09:32 PM
