brave one propshaft >
brave one propshaft
brave one propshaft
Old 02-18-2004 | 09:28 AM
BlownBajaOnHavasu
Default brave one propshaft
i have a 2000 bravo one performance drive, and i need a propshaft. any suggestions?
would a propshaft from a 1990 bravo one, and a 2000 bravo one performance be the same?
Old 02-18-2004 | 09:53 AM
Big Block Billy's Avatar
I Believe they interchange, but if you are making alot of power don't bother with the 1990 shaft. They are known to twist in the spline area. Especially if you hit something. I'm not too sure of the 2000 either.
Go to WWW.Mercruiserparts.com and look up the drives and compare part #'s. I bought a '90 drive online and realized the propshaft was twisted when it arrived. Merc makes an excellent kit with a billet carrier and a tough shaft and I believe gears , shims bearings etc.
The merc Part # is 840377a1
Lists for $1200 got mine on e-bay for $550 This is quality stuff. I never installed it yet though. BBB
Big Block Billy is offline
Old 02-19-2004 | 01:43 AM
WILDTHING TAZ's Avatar
B-MAX REPAIR
shaft is the same. i wouldn't buy a new carrier they are the same also. you can change the race in yours if it looks bad. a race,bearing,and seal is only a few dollars.
WILDTHING TAZ is offline
Old 02-19-2004 | 07:15 AM
marinetrans's Avatar
Imco makes good propshaft/carrier kits.BRV-128 has a billet carrier and special alloy shaft w/ larger bearing 675.00. BRV-128x has a billet carrier and large alloy shaft w/ even larger bearing 1025.00. Expensive kits but we have used both and have had no problems yet. Awesome machine work Imco does.
marinetrans is offline
Formula Outlaw
05-16-2006 05:16 PM
trader1
Apache
22
09-20-2002 07:43 AM
trader1
Apache
6
09-17-2002 03:04 PM
trader1
Apache
0
06-07-2002 01:07 PM
Ghia
03-22-2002 05:27 PM
