#6 drive oil change >
#6 drive oil change
#6 drive oil change
Old 02-21-2004 | 09:21 AM
27daytona's Avatar
Default #6 drive oil change
This will be a the first time that I have changed the oil on my wet sump # six drives. I have bravo experience but never a speedmaster. What is the oil capacity and do they drain and fill like the bravo? Should I run Redline oil as I have had good luck with redline in the bravo application. Thanks for your help. Doug
27daytona is offline
Old 02-23-2004 | 04:24 PM
HUSTLEthis's Avatar
Changing the oil on the wet sump #6 drive will be like the bravo...be careful when you open the lower drain screw, when I did it the oil came out fast...Have a 5 gallon bucket ready...It should hold about 4 gallons. When you pump the oil back in the lower hole, have someone look at the glass oil level window on the transom so you don't overfill. We run Torco in ours.
HUSTLEthis is offline
synack
8
10-17-2007 12:11 PM
MarkDonzi
Drives and Lower Units
1
07-19-2007 07:00 PM
Wobble
10
09-03-2004 09:05 AM
floatingphil
4
03-26-2003 10:23 AM
DanL
4
09-02-2002 12:50 PM
