3" slack in belt? >
3" slack in belt?
3" slack in belt?
Old 02-21-2004 | 07:53 PM
KH0302's Avatar
Default 3" slack in belt?
My 454 ran hot yesterday. 240. I shut it off when I saw the steam out exhaust. THANKS GOD I was pulling into my slip. I could spin the seawater pump pulley with my hand. So I took a pipe and wedged it to pull away and ended up with about 2 inch slack.
I think the shop used the belt from the 350 mag the pump came off and the pulleys are different size. No way that belt stretched that far, specially since it isnt new.
KH0302 is offline
Old 02-21-2004 | 08:41 PM
Tinkerer's Avatar
Just another reason why I do all my own work.
Tinkerer is offline
Old 02-21-2004 | 08:42 PM
Tinkerer's Avatar
You might want to do a compression check on both motors and compare the one that got hot with the one that didn't.
Tinkerer is offline
Old 02-21-2004 | 09:41 PM
marinetrans's Avatar
Must be a wrong belt.Merc has a couple of different size belts for seawater pumps. One belt has no cogs (larger belt) while the short one has cogs. Chances are you need the smaller one. I think the number off the top of my head is 57-13457t.
marinetrans is offline
Old 02-22-2004 | 06:41 AM
KH0302's Avatar
The one on it has NO cogs, thanks marinetrans.
Tinkerer, I WISH I had 2 engines in my 22' Pachanga!
KH0302 is offline
Cash Bar
10-25-2005 07:05 PM
R-Don
04-06-2005 10:57 AM
technicalx
0
07-22-2004 09:53 PM
kennyo
0
02-22-2004 08:45 PM
26sonic
2
04-25-2003 07:12 AM
