Shotgun Mufflers Illegal ?? >
Old 02-21-2004 | 10:48 PM
wwwTOPDJcom's Avatar
Question Shotgun Mufflers Illegal ??
I just removed my silent choice system because
In NY diverters are illegal, so Im going with stainless marine w/ stainless long risers and shotguns. Are these illegal too ?, I cannot see why, I cannot turn them off they are on all the time
http://www.cpperformance.com/products/Exhaust/024.htm
http://www.drewmarine.com/
wwwTOPDJcom is offline
Old 02-22-2004 | 01:38 AM
So what if they're illegal. Just stay quiet when you see the law or when your close to shore. Don't open them up until you're out from shore. Most people don't care about the noise unless you're too loud in the marina or docking at a watering hole.
The only reason they are "illegal" is so NY State can grab more money from you via a noise ticket. Don't let them win. Have some fun, just be aware of where you are when you're loud
Kidnova is offline
Old 02-22-2004 | 10:11 AM
formula31's Avatar
Top, I had shotguns on my Formula. I had dry pipes and the shotguns only dropped it 2 db. No where near enough to get legal. The whole cutout thing is a pain. Here in OH, at least in my part of Lake Erie, as long as you pass with the cutputs open, they wont ticket you. at least thats what all the cops I have talked to said. I would talk to the enforcement peopl where you will be boating and get their read on this too. The way most of these laws are written, its very open to interpretation. (a muffler is not defined-water acts as a muffler)
formula31 is offline
Old 02-22-2004 | 11:26 AM
I will be running them wet , I have seen them on many boats and them seem to quiet them down a lot
the back of powerboat mag has a add from Drew marine
stating that they are legal in all states
Old 02-22-2004 | 01:12 PM
Mr. Demeanor
They take the bark out of the exhuast but thats about it. I run them with the Bassett perforated insert type baffles. They work much better together and I saw no decrease in speed but I have a stock 330hp big block in an otherwise slow boat. Sounds healthy but not obnoxious.
Old 02-22-2004 | 01:28 PM
32storm's Avatar
work well around the dock and at idle. They take the bark out. Not sure how quiet, as never have tested the boat with a sound meter. NYS regulations say no cut-outs.....these don't have a cut-out. Also they are adjustable as to how quickly they open with the (3)position lever arm on the side.
32storm is offline
Old 02-23-2004 | 12:39 AM
I have them and they work pretty well. You can adjust them to keep them from opening as much with the spring rod.
I would say they are legal since they are always "on"
Even without any mufflers, I'm sure you are below the db requirement. You could adjust them to the lightest setting and meet the muffler requirement of the law.
Griff is offline
Old 02-23-2004 | 04:39 AM
BAD-HABIT's Avatar
It is also possible to adjust how much they open in addition to how fast they open...Important to know...I only need them to open about 1/4 of the way to not see ANY loss of speed per gps.......An alan wrench is all it takes to make the adjustment on rate and amount of opening...
BH
BAD-HABIT is offline
Old 02-23-2004 | 10:10 AM
Reckless32's Avatar
Rough Seas Lie Ahead
Can someone explain just how they work? Are they still muffled somewhat when open? Is is that they open from increase in exhaust pressure then close as you come off the throttles?
What about actuator arm clearance on the inside pipes of a twin setup?
Reckless32 is offline
Old 02-23-2004 | 05:48 PM
formula31's Avatar
Hi Rick, they are pretty much a spring loaded door, the more exhaust pressure, the more they open. I even put stronger springs in mine. The ones I had, shotgun 1's, had lefts and rights. I used the 2 lefts on the port engine and the 2 rights on the stbd. since my center 2 pipes were right next to each other.
I would worry about them being legal to a fussy cop. They are, in effect, automatic cutouts.
Tom
