High Water Pressure >
High Water Pressure
High Water Pressure
Old 02-23-2004 | 10:47 AM
Question High Water Pressure
LOOKING TO REGULATE MY WATER PRESSURE WITH SOME TYPE OF POPIT VALVE ANY IDEAS.NOW HAVE A STOCK SEAPUMP WITH A CROSSOVER AND THERMOSTAT AND PINS THE GAUGE AT 35 PSI AT THE INTAKE. EXHAUST SYSTEM IS FROM CMI-ETOPS ANY IDEAS
z.zuperboat is offline
Old 02-23-2004 | 11:28 AM
jdnca1's Avatar
PM Wette Vette, he has an easy fix that works extremely well. You can keep your thermostat also.
jdnca1 is offline
Old 02-23-2004 | 03:49 PM
Default Valve
Take that water pressure seriously, I just blew both my intake & head gasket with too much pressure. Merc has a valve
Merc
Water pressure relief valve
863208a3
About $110-00 from BAM , it's not available on regular Merc fisch, under performance section. Call Bam or use Wette Vette's system. Lower that pressure now not later. Do a search here & this are several threads regarding water pressure
Later John
Johno is offline
Old 02-23-2004 | 06:57 PM
racinbird
Do you need a speacial gauge to test water pressure? And where do you attach it at, Im getting some condensation build up in my valve covers and I have a cross over cooling system, I wanted to check the pressure. Thanks
Old 02-23-2004 | 07:26 PM
Kanookstr's Avatar
32' SUNSATION
Heres the link with picxs and instructions on the merc valve.merc pressure relief valve
Kanookstr is offline
Old 02-24-2004 | 01:06 AM
I would also check the water pressure in the block.
Griff is offline
Old 02-24-2004 | 08:54 AM
THE WATER PRESSURE IN THE INTAKE IS FROM THE SENDER HOLE SO IT SHOULD BE THE SAME AS IN THE BLOCK.AS TO RACINBIRDS PROBLEM CONDENSATION UNDER THE VALVE COVERS IS MORE THAN LIKELY FROM NOT ENOUGH OIL TEMP TO BURN OUT THE CONDENSATION.I HAVE TO RUN A THERMOSTAT FOR THAT REASON.
Ran-Dom 32
34
11-27-2008 10:57 PM
D Harry
10
06-19-2007 08:23 PM
chip12345
19
05-22-2005 05:25 AM
jeffg
24
06-18-2003 01:46 AM
GNJ2
4
12-26-2002 08:00 AM
