Decking Materials
You should be able to get it a little cheaper than that but not much. Trex and some of the other brands are the way to go IMHO. If you have kids or like to walk around bare foot you will love it, it won't splinter. If your not planning on keeping the place than just do it in wood, because you won't get your $ back out of it. They have a lot of colors to chose from also and all you ever have to do is clean it. I'm saving now to be able to redo my dock in Trex because I spen too much time pulling splinters out of my kids feet and my dock is in good shape. Where do you live? A good friend of mine owns a deck comp. maybe I can hook you up.
Trex is the first generation decking material. The problem with it is that it has wood fiber in it which means it will accept moisture. Therefore it can mildew, move quite a bit and also stain to the point that it can not be removed. If you are in a warm climate, Trex will accutally get too hot to walk as well as it will deflect between joist with the heat. This causes most applications to go to 12" on center spacing which adds to the overall cost of the deck. One of the second generation decking materials is GEO Deck. www.geodeck.com It does not have any wood in it at all so it won't stain, mildew, etc. Also, it is hollow so it won't get so hot and can easily span the 16" on center spacing for the deck joist. It is also a little more appealing to the eye and has a matching rail system. Either way, make sure you check out some of the new stuff out there. I don't think you would be happy with Trex if you saw some other options. Good Luck. Oh yeah, GEO has a 20 year warrentee and Trex is only 10.
I wouldn't use Trex for many of the reasons that Fountain CS has stated and more. I've personally seen it come apart after just a few years of use. Sure it's warrantied but who do you think is going to pay for the labor to replace it? I would go with Epoch or Iron-wood. Ironwood being my #1 choice.
OK while we are on the subject, what's the deal on the new type of pressure treated pine? I got an estimate to re-deck my dock and the dock company says the chemical they use to treat this new stuff reacts with metal (nails & screws) and they don't know what the long term affects are. Anyone have any details on this?
Of course they reccomended using some brazilian hardwoord called IPE. That stuff is like $3 a sq foot more but guarneteed for 25 years. Makes for a pricey dock!
Originally posted by DBELL6
Thanks for the info. I can't find Iron Woods website
Do not let them face nail it when installed.
Personally we used a plastic product called Trimax. It's made of recycled plastic and fiberglass. It's a light tan color. It was also a huge mistake, it get too hot in the sun to walk on bare foot. If I had to do it again I would use Ironwood. I would not use pine anything. I'm currently thinking about ripping off about 1200 sq ft of deck and replacing it with IronWood. I'll use the old deck material to re-deck the docks that are treated pine.
