Third generation RX-7
Old 02-27-2004 | 09:03 AM
JUSTONCE's Avatar
Default Third generation RX-7
Who's got em? What to watch for when buying, other than the fact they only get 45k on a motor ?
JUSTONCE is offline
Old 02-27-2004 | 09:16 AM
Cattitude's Avatar
bought a 22k mile 93 car from a Dr. in 99, kept it 4 yrs, strong runner, relatively cheap to insure, 100k miles is not out of the question (sold ours at 50 something)
They are not the most reliable- little things, few shops know them well, like turbo timers and gentle warm ups. apex seals like an oil additive in the fuel. Look up pettit racing in FL- they specialize and have lots of good scoop.
Cattitude is offline
Old 02-27-2004 | 09:35 AM
HyperBaja's Avatar
When the motor does go, a rebuild is almost 2k.
HyperBaja is offline
Old 02-27-2004 | 10:25 AM
SS930's Avatar
The motors aren't that bad, but the turbos do not last at all.
SS930 is offline
Old 02-27-2004 | 10:45 AM
JUSTONCE's Avatar
thanks for the input. I've had a couple 2nd gen non turbo's so I know the rotaries pretty well. If turbos are the biggest issue I'll be o.k. I got a few friends that do custom balancing and work with turbo's So I may just switch to a good single setup.
JUSTONCE is offline
Old 02-27-2004 | 10:55 AM
Cattitude's Avatar
The turbo's are fine if you change your dino oil every 2500 (no advantage to syn here) and use a turbo timer. these are hot running motors, no timer to properly cool at shut down and you're throwing cash away- large amounts. Good luck.
Old 02-27-2004 | 02:49 PM
BigSilverCat's Avatar
i went through a couple motors in my rx-7 i only put around 300 miles on it the whole time i owned it, but a .126 nos jet on it did not help.
BigSilverCat is offline
blckkat
Sea Ray
0
02-12-2008 11:31 AM
Quicksilver
12
02-01-2008 11:21 PM
G Man
Banana Boat
7
10-01-2005 07:52 PM
