Which pan gasket for GEN V 502? >
Old 03-01-2004 | 05:13 PM
Question Which pan gasket for GEN V 502?
I need to replace the pan gasket on my gen 5 502, its leaking at the bottom of the timimg cover where it meets the pan. Is there a special gasket I should use and are there any little tricks to increase the success of the replacement? Thanks Greg
HPJunkie is offline
Old 03-01-2004 | 06:07 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I used the Felpro. If I recall correctly, you are instructed by Felpro to put a bead of RTV in both the timing cover and rear main cap grooves before installing the gasket and in the corners as well. I had no leaks doing it that way.
US1 Fountain is offline
Old 03-01-2004 | 06:40 PM
38KV's Avatar
I use RTV all over the surfaces when I'm installing BBC oil pans.
And I'm not torque the bolts all the way before the RTV is dry.
Never a leak so far.
38KV is offline
Old 03-02-2004 | 06:51 AM
38kv did you say that you dont torque the bolts all the way until the rtv is hardened? Greg
HPJunkie is offline
Old 03-02-2004 | 11:40 AM
38KV's Avatar
Yes,I torque them about 50-75% of the recomended 80 lbs.inch for the 1/4" and 165 lbs.inch for the 5/16" when I install the oilpan,and torque them all the way the day after.
38KV is offline
fandango
05-17-2007 04:31 PM
daveintexas
5
05-12-2007 12:38 AM
98itrwhite
7
03-01-2006 10:17 PM
HARRISONMIRAGE
3
02-17-2002 01:54 PM
Audiofn
1
02-12-2002 06:38 PM
