Audio question... >
Audio question...
Audio question...
Old 03-04-2004 | 01:21 PM
Default Audio question...
Installing a 60w x 4 amp and a head unit. I need to run patch cables between the head unit and amp for L + R and the Sub pre outs. Went to Radio Shack and got the standard 3' audio cables. Salesman tried to get me to go with the gold plated contact cables. Said it would sound better. I doubted that you could hear the difference. The standard cables were about 6 bucks per pair and the gold ones were around 13 bucks. Would not the audio quality be determined by the least best conductor in the whole schematic (taking into account various frequencies and power levels)? I don't think the amp would be full of gold contacts.
Tim T.
BadDog is offline
Old 03-04-2004 | 01:26 PM
mikev's Avatar
on a boat you will deffinantly not hear a difference at all on a high end home or care system you might i personaly never have been able to tell the difference and wouldnt spend the cash.
mikev is offline
Old 03-04-2004 | 01:41 PM
So I should'nt spring for a gold plated gas cap either?
I sort of suspected that one could not tell the difference. If anything maybe the cable used in the gold connector model is of a better quality. Thanks for the info.
Tim T.
BadDog is offline
Old 03-04-2004 | 01:48 PM
mikev's Avatar
dude save the cash for the gold "grill for your mug" sorry could reisit been hangin with people from the hood again
mikev is offline
Old 03-04-2004 | 02:59 PM
formula31's Avatar
oh, Im sure audiofn will have something to say. The gold contacts are the only way to go where there is corrosion in my opinion. You wont hear the difference today but they will probably last longer.
formula31 is offline
Old 03-04-2004 | 03:03 PM
Well protected installation area and boat will be covered when not in use. Should be dry as a bone.
BadDog is offline
Old 03-04-2004 | 03:38 PM
formula31's Avatar
I also have a habit of using a di-electric grease to keep the air off of the connection which would help too. Youre probably OK. I tend to go overboard on some things.
Old 03-04-2004 | 04:05 PM
ragtop409's Avatar
NO................ not you Tom Rag's
ragtop409 is offline
ferraristyle
08-23-2005 02:19 PM
gdfatha
12-04-2002 01:02 PM
Dave1972
07-09-2002 11:45 PM
Dave1972
06-21-2002 03:01 PM
mfb357
02-12-2002 11:53 PM
