aluminum heads >
aluminum heads
aluminum heads
Old 03-09-2004 | 05:01 PM
dowhat
Default aluminum heads
What are the pros and cons with aluminum heads in marine applications?.. I hear Edelbroc makes a great set of heads for the HP 500. Is corossion a problem? Has anyone had any experience with aluminum heads? What do they cost?
Old 03-09-2004 | 08:47 PM
Havasu Cig's Avatar
I would be interested in an answer as well. I used Brodix aluminum heads on the motor in my last cat, but it was a fresh water only boat.
I have heard some say that they would be ok in salt, and some say they would not.
Havasu Cig is offline
Old 03-09-2004 | 08:56 PM
need to be hardcoat anodized, salt will eat the heads quicker than the fresh water , but even fresh water they will get eattin up just takes longer. best route is closed cooling, imho...
open87 is offline
Old 03-09-2004 | 09:34 PM
dowhat
Default Salt?
So.. How long would a set of aluminum heads in saltwater last?... If they were flushed well after each use in saltwater?
Old 03-10-2004 | 02:12 PM
I just built a 540 with AFR heads.I chose to go with aftermarket closed system and not worry about it.I've heard 3-5 yrs with open systems.BOB
Bob280Silencer is offline
Yellow_ICC_OK
3
04-11-2008 09:30 AM
Hy-Velocity
3
04-11-2005 07:59 AM
splashandburn
68
03-22-2005 08:07 PM
Smitty
47
12-20-2004 08:23 AM
Dave1972
6
12-09-2003 02:16 PM
