Fridge removal >
Fridge removal
Fridge removal
Old 03-11-2004 | 09:10 PM
Default Fridge removal
Contemplating going down to the boat this weekend. Would like to pull the fridge and remove dead amp. Is the fridge a ***** to get out? What- other than my standard tool kit of a dead-blow hammer and a chisel -do I need? Oh yeah- 1989 311 sr1.
SeaWeasel is offline
Old 03-12-2004 | 06:51 AM
Bill272's Avatar
All it took was a screwdriver on my 89 272. Piece-o-cake, like Troutly said.
Bill272 is offline
Old 03-12-2004 | 12:50 PM
jaybird's Avatar
Screwgun and wire cutters should do it. The fridge door will have to come off if you want to get it out of the cabin though. Just more screws to deal with. I took my fridge out of my '87 311 in about 15 minutes.
jaybird is offline
Old 03-12-2004 | 05:11 PM
Bill272's Avatar
I didn't need the wire cutters. Mine had a standard plug in the back with a long enough cord to get the fridge out before unplugging it.
Bill272 is offline
Old 03-15-2004 | 01:09 AM
RedDog382's Avatar
There are two phillips-head screws on each (R/L) side of the fridge. Take the black plastic plugs out to expose the screws, then slide it out toward you. The +/- feeds can be cut (make sure all power is off) and disconnects can be crimped back on for easy removal next time. Unplug the 110v and slide her out. Badda-boom, badda-bing. Done in under 5 minutes!
RedDog382 is offline
Old 03-15-2004 | 04:38 PM
PhantomChaos's Avatar
You just need a tank of gas and 6-8 footers. It'll pop right out without a single tool.
PhantomChaos is offline
jeff32
02-12-2007 06:26 PM
offthefront
06-02-2004 02:43 PM
Wally
08-01-2003 05:04 PM
PhantomChaos
05-31-2003 10:33 AM
