Which drive? >
Which drive?
Which drive?
Old 03-13-2004 | 09:52 PM
Danny_Ocean
Default Which drive?
Currently have a TRS w/tranny & 454/330. Next season I plan on ripping everything out and dropping in a mildly massaged 502. Due to the age of the boat (20 yrs.), I assume I will find rot in the transom and plan to have it rebuilt. As I'll be starting from "new" (no transom hole), what do y'all recommend for a drive set-up? I've seen all kinds of wild stuff lately (surface drives!), but not sure if I need anything that's race-ready (read: $$$). Someone also suggested an outboard bracket w/twin outboards.
Should I keep the ol' reliable TRS?
P.S. - Boat is 25' & 4500 lbs., "Cigarette" type hull.
Thanks in advance,
D. Ocean
Pompano Beach, FLA
Old 03-13-2004 | 10:13 PM
puder's Avatar
speel chekk this fokker!
trs shodul be fine or a bravo. SSM would be overkill.
Pardon me, while I whip this out!
puder is offline
Old 03-13-2004 | 10:14 PM
puder's Avatar
well if you have room maybe a ssm3 drive might not be abad idea. It will be damn near bullet proof with low power thru it and you can pick the older drives up for pretty cheap.
puder is offline
Old 03-13-2004 | 10:22 PM
Danny_Ocean
Yeah...I briefly checked out the SSM's. Sorry for my ignorance, but will the SSM lower bolt to my TRS upper?
D. Ocean
Pompano Beach, FLA
Old 03-13-2004 | 10:51 PM
lucky strike's Avatar
I think a #2 speed master is a TRS upper with a speedmaster lower. I would keep the TRS. They are bullet proof. Don't need the SSM on a 25' with a single engine. We have TRS on all our Cigs, never had a problem. my $.02
LS JR.
lucky strike is offline
Old 03-13-2004 | 11:12 PM
Danny_Ocean
Problem is, the TRS is so heavy, my arse sits way low in the water. Is the SSM significantly lighter?
D. Ocean
Pompano Beach, FLA
Old 03-14-2004 | 12:36 AM
puder's Avatar
ssm is gonna be as if not heavier.
eggbeater hanging off standoffs are goign to be worse becasue the weight will be further back. Bravo will move the engine back to the stern as weel becasue of teh lack of a tranny. If you are gonna run a bravo mayeb leave teh engein where its mounted and get a drive shaft custom made. Otherwise you might screw up eth COG on the boat.
Best bet, stick with the TRS.
puder is offline
Full Force
Drives and Lower Units
3
10-15-2007 07:29 AM
Canada Jeff
10
07-19-2007 02:38 PM
thayes11
0
10-02-2005 12:36 PM
Velocity Tom
07-16-2003 10:13 AM
panteraracin
3
02-07-2002 10:36 PM
