Gen 4,5,6 bb dist.... are they the same? >
Old 03-17-2004 | 06:14 PM
Default Gen 4,5,6 bb dist.... are they the same?
In other words, will a t-bolt IV dist work in a gen 5 or 6 motor?
454- 502?
Shah Mat is offline
Old 03-17-2004 | 06:28 PM
cstraub69@comcast
Yes.
Old 03-17-2004 | 08:02 PM
thanks
Shah Mat is offline
Old 03-18-2004 | 08:45 AM
ursus
bolt in but I believe the gear is of dif material because of the roller cam in Gen 6
Old 03-18-2004 | 09:42 AM
cstraub69@comcast
Shouldn't be, it is a cast roller core, should take a regular cast gear.
Chris
Old 03-18-2004 | 01:31 PM
GM makes a melonized gear for there roller cams.I believe the new gm rollers are made by crane so you could probably use the crane brass gear as well.
HARRISONMIRAGE is offline
Old 03-18-2004 | 02:56 PM
ursus
Chris
Perhaps it shouldn't be but it is, made from a different material, melonized, comp cams used to make a composite gear that supposedly would run on either , never tried them myself tho.
Old 03-18-2004 | 08:56 PM
mcollinstn's Avatar
distributor bodies are the same unless it is a talldeck.
Gear is the "same" as far as size and teeth, etc. But steel cams take different gears than cast cams. Some steel cams come with cast style gears on them.
mcollinstn is offline
Old 03-19-2004 | 09:04 AM
cstraub69@comcast
Ursus,
I am familar with the melonite gear and who makes them, it is not needed on OEM hyd. rollers out of EPC, or CMC, the 2 cam suppliers, one being an X division of crane, but it can be used an is a good idea.
The composite gears will not take heavy loads, I would not recommend them in a marine application. Ampco 45 bronze gears are used on the 8620 billets. There is a new cam core, 2 piece that is available. It allows for the use of a cast gear on a billet roller camshaft. Extended gear life compared to the Ampco.
Chris
GNJ
3
05-23-2007 12:15 PM
QUIKDECISION
2
04-25-2005 09:20 PM
Dave M
6
04-10-2004 07:18 PM
Geo 100
2
07-08-2003 06:28 AM
Valley Boy
0
03-28-2002 12:52 PM
