OK, one more question >
Old 01-31-2002 | 04:22 PM
NVRENOUGH
Post OK, one more question
SO i have pretty much decided to whipple my motor and run it till it blows, then replace it with something stronger. one qestion about the thru-hull pick up. can someone explain how they flow more water at idle and low speed. This shows how new to this I am. but i just can`t figure it out
thanks a lot
Jason
Old 01-31-2002 | 04:36 PM
Post
Hay dude good question I would like to know that one also since Im new to this game, anybody out that can help us. Thanks Tahoe
tahoez71 is offline
Old 01-31-2002 | 05:01 PM
Clay Washington's Avatar
Post
When I added my Whipple, I had a nose-cone and a low-water pickup installed on my Bravo 3.
Check out the pictures
Clay Washington is offline
Old 01-31-2002 | 05:11 PM
Smitty's Avatar
Post
Clay,
I know you always say "it's a Crownline" but I must say that is a great lookin' boat.
Smitty is offline
Old 01-31-2002 | 07:00 PM
Post
Originally posted by NVRENOUGH:
<STRONG>one qestion about the thru-hull pick up. can someone explain how they flow more water at idle and low speed.
Jason</STRONG>
Are you talking about a through hull pick-up for the engine cooling, intercooler flow or what? I just installed two through hulls on my boat,one for the motor and one for the intercooler.
Craig
mltdwn12 is offline
Old 01-31-2002 | 07:29 PM
Ted G's Avatar
Post
O.K. Let's try this. When a boat is moving through the water a low pressure area forms all around the hull. This has to do with fluid dynamics and movement across the hull. If you are moving slow the pressure drop is non-existant so you have water pressure pushing in on the through hull. When you start moving the pressure drops and can actually form a vacuum at the through hull-depending on how it's shaped. OTOH if you have a little scoop on it and it's facing forward you can force water pressure up and help the pumps out.
www.cbpba.com
Ted G is offline
Old 01-31-2002 | 09:27 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
Post
JUST TO ADD MY 2 CENTS I DONT HAVE THRU THE HULL. BUT IF YOU ARE IDLEING ENGINE ONLY NEEDS SMALL FLO OF WATER THAT WATER PUMP CAN HANDLE ON ITS OWN. THU HULL PICK UPS ARE GREAT BECAUSE SOME OF THEM YOU CAN ADJUST TO DIFFERENT HIGHTS,AND ARE A DIRECT & POSITIVE SOURSE OF WATER.NOT LIKE GOING THRU A OUTDRIVE LOWER CASTING,THEN THREW ALL THOSE INTERNAL FITTINGS.INCOMMING WATER LINES CAN ALSO BE LARGER IF YOU NEED FOR INNER COOLERS.FLOWING MORE WATER AT IDLE SPEED IS PROBABLY TRUE WHEN WORKED OUT ON PAPER UESING FLO RATES.BUT I THINK THIS SMALL FACTURE THEY UES AS ANOTHER SELLING POINT.
WILDTHING TAZ is offline
jaxx 30
Scarab
5
04-10-2008 09:49 PM
1Boatnut
02-20-2002 09:22 PM
