Hatch Actuators >
Hatch Actuators
Hatch Actuators
Old 03-25-2004 | 09:40 PM
aTX427's Avatar
Default Hatch Actuators
One of mine seams to be malfunctioning. Has any had any sucess with rebuilding the electic motors? It is a Warner Electric from Eddie Marine.
aTX427 is offline
Old 03-25-2004 | 10:38 PM
Hot Boat's Avatar
Team Dysfunctional
i pulled mine apart last season when it died. The brushes and contacts were filthy . I cleaned it up with some carb cleaner and re assembled it. It worked like new when I was done. Good luck
Paul
If it aint broke .... I can break it....
Hot Boat is offline
Old 03-26-2004 | 07:09 AM
Payton's Avatar
Charter Member #927
You should be able to find a replacement moter here if you can't rebild it.
http://www.grainger.com/Grainger/wwg/start.shtml
Payton is offline
Old 03-27-2004 | 04:00 PM
Strip Poker 388's Avatar
Rob
mine was real slow going up . tore it apart and it was dirty in the gear section , the motor was all rite.cleaned and greased and it working better
Strip Poker 388 is offline
Old 03-28-2004 | 09:49 PM
If you're going to take it apart to clean it, use electrical contact cleaner, or brake cleaner. It's a lot less nasty on the motor parts than carb cleaner.
Liberator21 is offline
509 SC
Sonic
0
09-29-2008 08:21 PM
brian valery
Velocity
6
06-10-2007 09:07 PM
Rocko C
Baja
0
06-12-2006 10:17 AM
Smitty
Baja
5
05-21-2006 05:19 PM
Active Mike
7
03-14-2006 11:07 PM
