Whipple Charger for a Fountain >
Old 03-26-2004 | 06:19 AM
Scott McKay
Default Whipple Charger for a Fountain
Will a Whipple Charger fit a 1995 Fountain 27' without back seat modifications? And can someone tell me who Dustin is and how to contact him? I see his name mentioned several times in discussions about Whipple Chargers. Are there any negatives to this modification?
Old 03-26-2004 | 09:39 AM
We're putting an Rtech Supercooler on a 27' Fountain that has Procharger M-3 system on it. The rear of the back seat had a spot cut out to clear the Procharger intercooler, but the supercooler fits easily behind the seat and under the top rail of the seat bulkhead.
The attached drawing has some measurements on it that may be relevant to your situation. If this is a carb engine you can relate these dimensions by measuring from the center of the carb flange.
tomcat is offline
Old 03-26-2004 | 11:01 AM
Breathe Later's Avatar
Scott:
Check out my post in the Fountain forums : 27 Fountain Project. I've got the 502 mpi motor with the older style Whipple. The new style Whipple, I believe requires no mods to the seat bulkhead. And YES, the system is definitely worth every penny. Contact : [email protected]
Breathe Later is offline
Old 03-26-2004 | 11:39 AM
Scott McKay
Thank you for the help! My guess is that I will need a prop change as well. Any idea what pitch and blad count?
SM
Old 03-27-2004 | 05:45 AM
INDY27's Avatar
start with a 30p rh Bravo, its the best for the money spent.
AUTOCONNECTIONLLC.COM
INDY27 is offline
Old 03-27-2004 | 09:57 AM
JimV's Avatar
How fast you guy's going in a 27 with the supercharger?
JimV is offline
Old 03-27-2004 | 04:41 PM
Hi Jim, how's it going? Can't answer your question yet.
tomcat is offline
Old 03-27-2004 | 05:24 PM
JimV's Avatar
TomCat
I'm doing great, how you doing?. let us know how fast you go
JimV is offline
Old 03-27-2004 | 07:15 PM
27 FOUNTAIN's Avatar
91' 27 w/509,crane 731 ,bm 250, 7 lbs boost, 5500 rpm, rev 4 23p prop, 80 mph gps.
27 FOUNTAIN is offline
Old 03-27-2004 | 09:05 PM
paradigm shift's Avatar
What ratio you running in your Bravo. 1.36?
paradigm shift is offline
