upper steering shaft seal >
Old 03-29-2004 | 09:05 PM
johnnyboatman's Avatar
Default upper steering shaft seal
does anyone know the part # for the replacement upper shaft seal with the two plugs that u can change from the outside on a bravo one?
johnnyboatman is offline
Old 03-30-2004 | 06:41 AM
razor1115's Avatar
Lightbulb sorry
No part #'s as I am at work...and I believe this is changed from the outside. I don't remeber off the top of my head, but I think the tiller arm has to be removed from the inside of the transom assembly. However, you need to make or use a special puller on the pin. The pin is hardened and pressed in ALUMINUM. By the time I bought the tool and did it myself and possible took a chance on busting the Al transom assembly, I figured I was money ahead to let a mechanic do it. If he broke the assembly, I'm not out huge $$$$. The job was EXPENSIVE. Something like $600. Merc thinks that pin is made of gold ( I had to replace mine and the seal). Pin was like $240. If I'd a known that, would have made my own and case hardened it myslef...
Good luck,
Zack
razor1115 is offline
Old 03-30-2004 | 06:48 AM
marinetrans's Avatar
Access hole kit #22-88847a1, seal is #26-41607-1.
marinetrans is offline
Old 03-30-2004 | 08:35 PM
yes im fixing to let a boat mech do it .
epeek
6
05-23-2012 05:26 PM
scarab74
3
06-10-2007 09:27 AM
blackhawk
07-28-2004 02:14 PM
edb07
7
02-15-2004 06:39 PM
THRILLSEEKER
3
10-15-2002 02:04 PM
