Go Back  Offshoreonly.com > Owners Forum > Powerplay
prop testing >
prop testing
prop testing
Old 04-02-2004 | 07:32 AM
Default prop testing
Hey guys I going to Throttle Up on wed to do prop testing on my 33 powerplay. we are going to test a bunch of different props including 5 blades. I hoping to get 94-95 out of her, i guess we'll see. I'll post the differences between the props.
baja27 is offline
Old 04-07-2004 | 09:55 PM
TO THE WOOD's Avatar
GOOD LUCK, THOSE GUYS KICK ASS. THEY DID MY PROPS AND THEY ARE ON THE MONEY...ARE YOU RUNNING SHORTY'S?
TO THE WOOD is offline
Old 04-09-2004 | 05:55 PM
frequentflyer's Avatar
So how did you do?
frequentflyer is offline
Old 04-14-2004 | 10:48 AM
To the wood, yes I running shorties. Well here's the story, tried 28" 5 blades getting on plan was alittle easier by 400 rpm cruising was about 5mph better but lost top end 3mph. These where stock blades. Tried a pair of 29 hydros boat did not like it at all.
To the wood and PP33 what brand and type of prop are you guys running?
baja27 is offline
Old 04-14-2004 | 05:11 PM
BAJA 27
WE RUN 30 BROVO'S , I HAVE RUN 29 HYDROS ON MY BOAT AND IT LOVED THEM..THE RIDE WAS THE GREAT.. I CAN SPIN THE BROVO'S TO A HIGHER TOP SPEED,I NEED MORE POWER FOR THE HYDROS. MY 30 BROVO'S WERE LAB'D BY THROTTLE UP THEY WORK GREAT. WE ARE GOING TO WORK WITH THE 29 'S THIS SUMMER AFTER WE ADD MORE HEAT WE DO NOT HAVE SHORTY'S AND THE HYDRO'S DO NOT PLAIN AS WELL AS THE BROVO'S ..DID YOU GUY'S FIND A COMBO. THAT WORKED? DID YOU GET MORE SPEED? WHAT WAS ON IT WHEN YOU WENT?
Old 04-14-2004 | 07:58 PM
baja 27, we both have labbed 30 bravos. They are reworked slightly different though. Do you still have revlimiters at 5150rpm, or was that modified with the procharger install? What props are you running now? You are welcome to try my 30s, but you will have to be able to turn at least 5400-5500 rpm to run over 90mph. Just let me know . Good luck.
PPlay33 is offline
Old 04-15-2004 | 08:01 AM
To the wood & PPlay 33 I run 31 bravos now at 5,500 rpm so far I get 90. I looking to get 92-94 mph out of her. I also have different cams in the motor, it's basically a hp500 motor with prochargers. I'm also thinking about about running more boost. Currently I run 4 pounds, thinking about bumping it to 6psi? What do you guys think? The motor is studded also.
baja27 is offline
Old 04-15-2004 | 07:36 PM
baja27, you should be able to run more boost easily. The procharger setup should be intercooled, so it will be safe. I would like to go for a ride just to compare it to the other ones I have been in. Keep plugging away at it, you should get that speed!
PPlay33 is offline
Old 04-15-2004 | 10:09 PM
Ambrose on the Thunder Marine Poker Run
Boat looks awesome
Johno is offline
Old 04-15-2004 | 10:10 PM
Ambrose/Baja 27??
Johno is offline
