bell housing hinge pins >
Old 04-03-2004 | 10:37 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default bell housing hinge pins
Bravo One with the trim senders in gimble ring.
What everyday tool will tighten the side hinge pins? 1/2" allen socket wrench? Thanks
US1 Fountain is offline
Old 04-04-2004 | 06:41 AM
Mbam's Avatar
Offshoreonly Advertiser
Hard to get enough torque on them without the Merc 12 point tool.
Mbam is offline
Old 04-04-2004 | 10:42 AM
blue thunder's Avatar
I use a socket mounted allen driver. Never had a problem.
BT
blue thunder is offline
Old 04-04-2004 | 11:38 AM
Ginger or Mary Ann?
BT
Dave,
That is my thought too. It is spec'd at 90-100 ft lbs, so that is not a conscern. This is on a freinds boat that is an hr away that I happened to catch while doing the drive service maintance yesterday. Just needed to know if the 1/2" was correct before drving back down there only to find out it is a bastard size. Or is it bigger? Had no tape measure to check while I was there.
Old 04-04-2004 | 12:09 PM
formula31's Avatar
Yes, it is 1/2".
Tom
formula31 is offline
Old 04-04-2004 | 03:58 PM
Tinkerer's Avatar
Make sure to put lock tite on it.
And if it got loose the threads might be buggered up.
Tinkerer is offline
Old 04-04-2004 | 04:55 PM
That's what happened to mine. I had to heli coil them.
BT
Old 04-04-2004 | 07:14 PM
Ginger or Mary Ann?
Thanks guys!
Old 04-05-2004 | 08:38 AM
Do yourself a favor and spend $10 on the merc 12 piot tool.
Gary
Gary Anderson is offline
Old 04-05-2004 | 11:13 AM
marinetrans's Avatar
Gary's right.If you ever have stripped out a hinge pin and had to drill it out, you wish you had bought the tool.#91-78310.Fits Alpha,TRS and Bravo.
marinetrans is offline
