transom soot- cleaning
Old 04-05-2004 | 12:00 AM
Default transom soot- cleaning
Whats the best cleaner to use to get rid of transom soot?
poolshrk is offline
Old 04-05-2004 | 05:59 AM
mama tryed's Avatar
Elbow Grease and quit running Premium!! If all else fail's,, I use Acetone!!-{spell Check}
mama tryed is offline
Old 04-05-2004 | 06:03 AM
MnFastBoat's Avatar
Charter Member#157
stop running premium??
Does Premium gas actually give more Soot??
I would think it would burn cleaner
Maybe that is why mine is so dirty, because all I run is 90+
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 04-05-2004 | 06:23 AM
Chris's Avatar
Try Simple Green, the stuff works GREAT on transom soot!!!
Chris is offline
Old 04-05-2004 | 06:30 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Lowest octane you can run without pinging and Simple Green. Also, assuming you have an EFI, as the season warms up a bit, your soot will decrease.
Sydwayz is offline
Raypanic's Avatar
!Black streak remover! Starbrite. Works great
Ray
Raypanic is offline
Old 04-05-2004 | 06:37 AM
Canada Jeff's Avatar
If you keep the transom waxed, it helpes too.
Canada Jeff is offline
Old 04-05-2004 | 06:51 AM
Macklin's Avatar
Premium will make the computer / engine run rich which increase soot.
Keeping the transom waxed definitely makes clean up much easier. For the really tough soot go to West Marine and get a bottle of Black Streak Remover that Ray mentioned.
Macklin is offline
Old 04-05-2004 | 07:26 AM
throttleup's Avatar
After you remove the "soot". I highly recommend that you apply Frenzy. This will aid in removal the next time around. You will literally just have to wipe it off. I have seen this with some of my race clients.
Julie
throttleup is offline
Old 04-05-2004 | 08:17 AM
BajaRunner's Avatar
formula 505 from home depot, works great
BajaRunner is offline
