Aluminum heads in saltt water?? >
Old 02-07-2002 | 09:44 PM
cdaniel525
Post Aluminum heads in saltt water??
I was wondering if aluminum heads will corrode in salt water over the years?? I have seen a lot of talk about them being better and was considering using aluminum when i rebuild the top half of my SBC this spring. Is this the same case with aluminum intakes??
Old 02-08-2002 | 12:34 AM
Audiofn's Avatar
Charter Member #232
Post
You can if you are rebuilding go with a closed system and then you will really have a long lasting set up
Jon
Put your best foot forward!
Audiofn is offline
Old 02-10-2002 | 12:52 PM
cuda's Avatar
Post
I just put closed cooling on my new engine because of aluminum intake. I think it will be worth the investment. ($570). It will also legnthen the life of the exhaust manifolds. Another advantage of the closed system is the ability to run at a higher temp, so the engine is more efficient. It isn't a very hard job to install the closed system either.
Very sweet boat by the way. I love a restored classic boat. I am restoring an 81 Formula.
[ 02-10-2002: Message edited by: cuda ]
cuda is offline
Old 02-12-2002 | 11:39 PM
cdaniel525
Post
Thanks guys...
Im gonna look into a closed system... cuda...yours was $570 for both motors or just the one??
Good luck with the formula
BTW, ur name "cuda" referring to a plymouth barracuda??
Old 02-12-2002 | 11:41 PM
cuda's Avatar
Post
It was $570 for a full system (includes exhaust manifolds) for one small block chevy. The nickname is short for Barracuda, it is a name that has been with me for years.
cuda is offline
Old 02-14-2002 | 06:51 PM
blue thunder's Avatar
ttt
blue thunder is offline
ghittner
29
06-05-2015 10:13 AM
formula 382 sr-1
10-12-2008 01:45 PM
two-rocks
0
06-27-2007 07:42 AM
Dave1972
6
12-09-2003 02:16 PM
Ted G
4
03-04-2003 08:05 AM
