Trailer Axles >
Trailer Axles
Trailer Axles
Old 04-17-2004 | 01:08 PM
MnFastBoat's Avatar
Charter Member#157
Default Trailer Axles
Any OSO memebers on here distribute them?
Looking at replacing all 3 of mine
Currently have leaf and want to go with torsion.
is it difficult to change?
also want to go from drum to disc
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 04-17-2004 | 01:23 PM
Hi-Tech Marine's Avatar
Default Axles
Email me with you contact information.
[email protected]
I need the inner frame width and the width of the frame material itself (aluminum or steel) for the torsion mounting holes and the type of bake coupler you have.
Also need the rated capacity of the trailer (GVWR), tire size you are using, Number of lugs in your hubs and the distance from the spindle to the fender vertically.
Generally you will have to modify the coupler when converting from drum to disk.
Hi-Tech Marine is offline
Old 04-17-2004 | 04:41 PM
MnFastBoat's Avatar
Charter Member#157
Default Re: Axles
[email protected]
OUCH
I was afraid of that
I will get the measurements this coming week, maybe tomorrow it the rain does not come.
Maybe I will have to stay with drum becuase the actuator is built into the trainler tongue. All one peice.
How much$$$ of a ball park are axles like this?
it currently a 3,000lb trailer
gvwr is 9,000
and i am only running 3400lb axles. to close to max load
14" tires 5 hole.
thanks
Old 04-18-2004 | 08:55 AM
3500lb torsions are around $375.00 + shipping. I am ballparking here. I will have to check on Monday. I may be able to save you some by having them drop shipped. Spacing will be the determining factor on availibility.
I will get you the instructions for modifying your drum actuator to disk. It's relativly simple. The brand and model is needed. I am assuming you have the reverse lock out solenoid on your actuator.
Old 04-18-2004 | 09:15 AM
Downtown42's Avatar
HI TECH- I have a myco 1993 tandem 12,000# for 35 Lightning. Cannot get a jack under the middle of leaf springs close to the wheel. Is it ok to just jack on the round axle tube as close as possible to the wheel? I don't have enough clearence to where I prefer to locate.
Downtown42 is offline
Old 04-18-2004 | 07:19 PM
Downtown, Myco uses a heavy axle tube in their trailers. Spring axles take all types of flexural loads in tow. I have a 42 Fountain in the yard with a Myco needing some repair work and jacked it in the same location. The axle on your trailer should be fine locating the jack just inside the springs.
Old 04-18-2004 | 09:45 PM
Downtown42's Avatar
Tnks HI TECH
MILD THUNDER
2
09-07-2008 01:04 PM
J.B. Marshall
04-12-2006 05:20 AM
MnFastBoat
6
08-02-2004 10:23 PM
Tantrum
03-16-2004 10:34 AM
euby
12
07-22-2003 08:42 AM
