351 idling rough, help me OB1 >
Old 04-19-2004 | 04:27 PM
BajaRunner's Avatar
Default 351 idling rough, help me OB1
351 in a ski boat.
idles rough, dies, will not run on its own without throttle.
takes off fair, but runs ok once moving, but will occasionally hiccup (backfire).
has a new carb, and all tuned up.
what do you think? bad cam lobe or burnt valves?
BajaRunner is offline
Old 04-19-2004 | 05:04 PM
offthefront's Avatar
If it got hot ....could be water in cylinders ..pull a plug and check for water ....
offthefront is offline
Old 04-20-2004 | 09:05 AM
BajaRunner's Avatar
ill do that. i was thinking more towards cam and burnt valves though?? the boat is my brothers, and at this point he will check anything.
Old 04-20-2004 | 10:31 AM
Tune up = new plugs + wires + cap + rotor + checked timing and advance?
Fuel supply & quality OK? New fuel/water separator? No water in gas tank? Good fuel pressure?
Have you done a compression check?
Gary
Gary Anderson is offline
Old 04-20-2004 | 01:02 PM
BajaRunner's Avatar
Gary
just got off the phone with him. tune up stuff, all done, fuel is good and ok, new fuel/water, has NOT checked fuel pressure.
but if it had low fuel pressure then how would it run top end ok?
Old 04-20-2004 | 01:54 PM
Poor idle and the symptoms you described are usually due to too rich condition. Are you sure the carb doesnt have a blown power valve or stuck float (Holley?). Is the choke opening?
What do the plugs look like, black? Again, this could indicate rich condition, or bad fuel, or bad spark (coil OK?)
Compression check should indicate if it's avalvetrain problem.
Gary
Old 04-20-2004 | 01:57 PM
BajaRunner's Avatar
i posted on the problem before and the consensus was a bad carb, so he bought a new one.
he needs a compression test next.
Old 05-07-2004 | 03:58 PM
BajaRunner's Avatar
he didnt do a compression test, but instead took it into a shop. they did one, and heres what they found.
on one side, 2 dead cylinders, pulled the heads and ones a gt-40 head and ones regular. they said it was sucking the valves down and ruined them
getting a matched set of heads and putting it back together.
Old 05-07-2004 | 07:57 PM
Hey...I'm working on that boat!
Bob
bobl is offline
Old 05-10-2004 | 08:05 AM
BajaRunner's Avatar
thats it
zdek
Grand Lake/LOTO/E-Dock
9
04-22-2008 03:07 PM
UNSANE
Members On-line Video Section!!
4
10-25-2007 05:19 PM
TeamSaris
0
10-05-2007 06:16 AM
davids94
05-14-2005 08:35 AM
Miguel
4
07-02-2003 07:46 AM
