whats the rpm on a 502?
I have a marine crate engine 435 hp 502, i would like to know what its the maximum rpm i should be running this engine before the hp starts to go down?
thanks in advance
thanks in advance
Well probably not??? You should try some different props with your engine max rpm in the 4600-5000 rpm range.
I tried a number of props on my boat last Summer.
My boat went faster with a 26p spinning slower than a 24p faster. I am assuming that the engine went past it's peak power with the 24p.
Patrick
Patrick
Do You have a 24' Pantera?
Talk to Jo at Pantera.
He'll likely tell you to start with a 25p Mirage plus or a 26p Bravo one.
You should run about 73mph in fresh water and about 75mph in salt.
Good Luck!
Good Luck!
Patrick
Patrick
wwwTOPDJcom
06-10-2003 06:09 AM
