Adding Oil Heaters
Old 04-27-2004 | 08:35 PM
Charter Member # 1215
Default Adding Oil Heaters
I was at a Dinner the other night, where I had met the owner of a NASCAR TEAM, while discussing engines he had suggested to add oil heaters which would add a tremendous amount of engine life (preventive maintance) , curious if anyone has done this setup with 500EFI.
topgunrcf is offline
Old 04-27-2004 | 11:27 PM
Reed Jensen's Avatar
I've never seen it installed on a boat.... the way they work in a nascar is they are plugged into a wall outlet before they start the car... the oil pan has a heater inside.... the oil is preheated to 200 degrees so that it flows better upon start-up.
Reed Jensen is offline
Old 04-27-2004 | 11:30 PM
Strip Poker 388's Avatar
Rob
I don't think you need it . Most of them use it on there dry sump tanks . I don't use them on any of my race cars or my blower motors and I have never had a bearing problem .
If you where up north cold cranking it might be a consideration.it would be easier to crank.
I do always wait till I see the oil temp gage move before calling on it. The Hustler has a Oil thermostats . It takes about 10 min to get some oil temp
Strip Poker 388 is offline
allenk4
22
08-08-2007 01:59 PM
Cord
2
04-17-2006 07:15 AM
boatinbill
2
03-06-2005 08:27 PM
dyno
19
06-08-2004 07:58 AM
scervin
2
07-17-2003 08:44 PM
