fuel water seperators? >
Old 05-09-2004 | 08:41 AM
micky dee
Default fuel water seperators?
what is a good quality water seperator to use? they will be used on a 454 gas engines.
can these seperators be used in series with the stock seperators or will the flow be reduced too much. thanks in advance
Old 05-09-2004 | 09:17 PM
micky dee
anyone?
Old 05-09-2004 | 10:57 PM
Why would you want to run a second one???
The stock water sep filters work fine. I've had h2o in my fuel and the filter was full of water.
Griff is online now
Old 05-10-2004 | 03:20 PM
Hey Griff,
Why a second filter ?
I run a second filter inline because I have EFI's with VST tanks and the standard Merc or anyone water seperator/fuel filter from Merc is rated at 70 Microns. That's not nearly fine enough to really protect the VST screen. I had, as have numerous OSO members, many problems with clogged VST screens. No more. I use a RACOR after my Merc filter and have experienced no problems in over 250 hrs. The standard Merc filter will not eliminate debris capable of sticking a needle in a Holley carb.
It's not unreasonable to run two filters. Most probably will not need it. But, some may benefit from two.
deboatmon is offline
Old 05-10-2004 | 06:00 PM
Krumbsnatcher's Avatar
I use the fram HP filter separator and it works great, nice drain plug on the bottom to eliminate the water and they come in both 8 and 11 inches, so depending on your fuel consumption requirements you are covered.
Krumbsnatcher is offline
Old 05-10-2004 | 11:47 PM
I can see running a second filter to filter out smaller particles than the merc one, just don't see the purpose of running a second water sep filter.
Griff is online now
Old 05-11-2004 | 04:00 AM
BAD-HABIT's Avatar
So which fuel filter/water seperator is the best? Which one has the highest ratings? I really don't want to put an inline filter also on the boat if I don't have too. If I can get a 2/for 1 job I rather do that...You mention Fram what are it's ratings?
BH
BAD-HABIT is offline
Old 05-11-2004 | 08:11 AM
FRAM is a powerful marketing company. RACOR is probably the most widely accepted professional filter system for your boat.
I use RACOR with the metal bottom. They are available at most marine supply stores. Boaters World, etc.
Good luck.
BOATMAN302
1
08-07-2007 09:24 PM
Higgs
02-28-2007 06:25 PM
Vinny P
05-24-2006 01:24 PM
JnT
0
09-11-2005 11:43 AM
baja272
7
06-24-2002 11:31 AM
