Fiberglass Repair
Ok I now have my project at home. Time to start filling all the old dings and scratches to get ready for new paint. Most are pretty deep so I will have to grind out some of the old exposed glass and start new. I am wondering what fiberglass products you are using to fill these scratches. Also I will be glassing over the old portholes. Any special tips or tricks? I have a few fiberglass repair books on the way. It is something that I want to do, just want to try and get it right the first time without hiring a pro...All help appreciated. The boat is a 1979 Formula 255.
Get the West System book on fiberglass repair. Even if you don't use West it gives some really good ideas on prep, tricks, etc.
My body shop buddy told me this.........
If there is an area (like filling a hole) and you need a temporary backing, you can use cardboard. But first cover it with masking tape. The fiberglass resin does not stick to the non-sticky side of masking tape very well. Once it sets up, you can pull it away.
And.......
I have found that the plastic caps from stuff like Brakeen, carb cleaner and paint cans make excellent little mixing bowls for the resin and hardener. Get a box of these brushes to mix it with.
http://www.harborfreight.com/cpi/cta...emnumber=41338
