Stellings standoff box alignment
Official OSO boat whore
You do not need a long alignment tool for the Stellings box. There are actually two places their system is aligned too. One is the main carrier bearing. The second is at the transom assembly. The main bearing would have some large parallel ground washers under it. Usually people don't realize the bearing actually has an alignment, take it apart and mix up the shims. Good luck getting it to align. I actually had to send my box back to Stellings for realignment. After that you make the final alignment with the transom assembly. Leave the bolts a little loose and just slide it around until things work out.
Thanks Cord
I tried to loosen the bolts holding the bearing carrier but when I turn them it does not feel right do you know
if the nut on the bottom is a lock nut and the box is threaded or is it a thru hole?
Ed
Ed
The bolt passes through the hole. Unless you know that the center bearing is messed up, try to align with the gimble.
Its not off much but it does bind up and it is hard to get the drive on and off. The other drive is perfect. I did break a gear last year in the drive on the side i am having problems with and don't know if this may of had
anything to do with it.
Ed
Ed
