mercruiser motor number >
Old 05-17-2004 | 08:07 PM
boatn70's Avatar
Default mercruiser motor number
if i get the number off the block,or mercruiser tag, where can i look up what it is. im looking at a used 502 carb motor, owner says that its a 420hp. but after asking around everybody says the 420 was a 454. the number givento me was taken from near the bell housing and is F224424. does that do any good to you guys?
thanks for the help
kevin
boatn70 is offline
Old 05-18-2004 | 06:12 AM
Default Re: mercruiser motor number
Punched that # into mercruiser epc and it said "454 efi ski engine",model #374B169GS.Hope this helps.
Jeff
PROFILE is offline
Old 05-18-2004 | 07:44 AM
tanned fat looks better's Avatar
hey can you punch in D602746 and see what you get?
tanned fat looks better is offline
Old 05-18-2004 | 08:31 AM
The 454 420hp motor was a variation of the 400 cyclone. It had gil exhausts, I think. Built late 80s/early 90s.
The base 502 comes as a 410hp version. That may be what he's referring to.
See if you can get the block code off the front of the block. That may be a better indication of what it is.
Gary
Gary Anderson is offline
Old 05-18-2004 | 04:53 PM
look down on the motor were the bell housing bolts to the block(left side) thats the casting #.Also it will have either 7.4 or 8.2 cast on the side of the block about where the motor mount is.
Dixie Doug is offline
Old 05-19-2004 | 06:04 AM
D602746 =502 magnum bravo engine.
PROFILE is offline
Hydrolift
9
02-08-2013 01:22 PM
JRider
18
08-28-2008 12:49 PM
idareya
0
03-30-2005 08:36 AM
Peconic
General Racing Discussion
24
06-07-2004 08:18 PM
