Battery Switch Swap >
Battery Switch Swap
Battery Switch Swap
Old 05-20-2004 | 11:10 AM
waterheater's Avatar
Default Battery Switch Swap
Any advice on swapping battery switches? Have a Guest and am switching to a lockable Cole Hersee. Not sure of degree of difficulty. Any suggestions?
waterheater is offline
Old 05-20-2004 | 07:28 PM
Mr Gadgets's Avatar
Charter Member #601
Default Re: Battery Switch Swap
WaterHeater..
It is a simple process, just disconnect your batteries and remove the Guest from it's mounting place. You should see two inputs from the battery and one output going to the starter..
The new switch should be the same..
Just remember to disconnect the battery cables from the battery before you start.
Good luck
Dick
Mr Gadgets is offline
Old 05-25-2004 | 07:08 AM
Thanks Dick, appreciate the advice. Sounds simple enough.
muffman
0
04-09-2006 11:36 AM
Gary C
26
07-29-2002 04:37 PM
