excite wire voltage >
excite wire voltage
excite wire voltage
Old 05-24-2004 | 09:37 PM
jet454jet
Lightbulb excite wire voltage
undefinedundefinedundefined i need to know what the correct voltage should be to the excite wire on my 78 tahiti...it has 10.50 to the excite now and batt voltage is 12.5..i have a new alt and reg and am not getting voltage out of the alt..also, is there a specific rpm it need to be to excite???thanks for any advise
Old 05-25-2004 | 12:48 PM
Default Re: excite wire voltage
There should be a full 12 V on that wire. It's switched on by the key, so check your ingition switch for corrosion. Not sure if slightly lower voltage would affect it though.
Depending on the alternator, you my have to get it above 1000-1200rpm before it will start to charge, but then should continue even at lower rpm.
Gary
Gary Anderson is offline
awsomethunder
2
04-27-2007 09:31 AM
waybomb
1
02-12-2006 10:17 PM
CC247
3
07-20-2005 11:12 AM
MILD THUNDER
7
10-18-2004 07:40 PM
greg hacker
4
06-25-2003 10:09 PM
