Water pressure on hose with muffs. >
Old 05-28-2004 | 06:54 AM
tssteph's Avatar
Default Water pressure on hose with muffs.
Should there be some water pressure when running on the water hose with muffs? I started the motors for about 30 seconds each on the hose but I did not see the water pressure gauges move. Is this normal? My guess is that the hose does not have enough volumn.
tssteph is offline
Old 05-28-2004 | 07:57 AM
Smitty's Avatar
Default Re: Water pressure on hose with muffs.
I have never seen any pressure while on the hose. Be careful to not rev up too much on the hose, because there is not enough volume. The seawater pump will actually collapse your hose and starve the pump for water.
Smitty is offline
Old 05-28-2004 | 08:01 AM
tssteph's Avatar
Thanks, thats kinda what I figured. This is the first boat with gauges for me.
tssteph is offline
Name That Boat.com
Drives and Lower Units
4
09-20-2007 10:04 PM
eliminatethis
5
06-29-2007 07:12 AM
corbvette
1
06-26-2006 09:40 PM
gripit
10
05-07-2005 10:32 PM
Raypanic
Fountain
3
09-24-2003 05:29 PM
