vee drives
Old 05-28-2004 | 08:28 PM
micky dee
Cool vee drives
with regards to a prior post, the sound of a grinding bearing has returned! again the mechanic came to listen the problem. he advised that a spring coupler is sticking? he also mentioned that the idle was too low. once we bumped the throttle up a hair the noise goes away. anyone heard of this? or anyone got a picture of this coupler. he advised that there is no danger and to try it out on the lake. any thoughts .
Old 05-28-2004 | 08:34 PM
Mbam's Avatar
Offshoreonly Advertiser
Default Re: vee drives
It's common, lots of gears with back lash. At idle they kind of dance around. Sam issues with the newer Hurth & Velvet Drive 5000 series. There is an elastomeric coupler that will get rid of some of the rattle, but aside from being annoying it should not be problem.
Mbam is offline
Old 05-28-2004 | 08:46 PM
micky dee
thanks, i will try her out tomorrow then and hopefuly evething goes smooth!
TeamSaris
Spectre
1
01-21-2006 08:48 PM
FtLaudGranPrix
05-15-2003 01:39 PM
THEJOKER
03-12-2003 07:32 PM
Dean Ferry
11-27-2002 08:09 AM
