bravo 1 ?
Old 06-02-2004 | 09:37 AM
Default bravo 1 ?
was changing my props last nite noticed that the one drive has a upper clunk noise that the other one does not have . i hear the noise when i spin the prop back and forth when it comes to a stop spinning it backwards. when spinning it over it sounds normal and i had no problems in the water over the weekend. a possible u joint or what.
thanks 32 thunder rick
rssteiny is offline
Old 06-02-2004 | 11:39 AM
WILDTHING TAZ's Avatar
B-MAX REPAIR
Default Re: bravo 1 ?
I Doubt It.when You Spin Your Prop By Hand You Are Only Turning The Lower Not The Upper. It Sounds Like You May Have A Bad Bearing Or A Chipped Lower Gear. Or A Worn Out Lower Gear Set.
WILDTHING TAZ is offline
Old 06-03-2004 | 09:04 AM
thanks
any more info as to what i can check
rssteiny is offline
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
