k plane hydraulic line replacement
On a Sonic 31 the lines that crossed over the trim pump lines from the kplane
lines had a short .When they shorted the lines to the kplane burned a hole
in one or both lines . We need to know how to replace the lines .
do you pull through the kplane ? I can not reach the inside of the hull
on the back side of the kplane . The short was caused from the stainless steel
touching the positive terminal on trim pump. This is a new boat ,the dealer is 5 hrs away.
