F 350 Dually
Old 06-03-2004 | 03:43 PM
Madcow's Avatar
Default F 350 Dually
I'm thinking about buying a 2001 Ford dually with a powerstroke. Anyone know what kind of milage I will get with this? Also any negative feedback I should watch out for? Thanks all.
Madcow is offline
Old 06-03-2004 | 04:00 PM
turbosonic1's Avatar
Default Re: F 350 Dually
I have one and it is a great Truck. It is the first Ford I ever owned and it tows great. I have the Banks Stinger Plus System on it and I get about 16.5 around town. I ordered it with all of the towing stuff so the gearing is high.
I tow my Formula 382 with it ~14,500 lbs with the trailer and I smokes up hills, the Dually is totally stable towing in high winds and when being passed by a Semi!
I can pass my friends with similar weight boats on any grade..one has a Freightliner FL60 and the other a Kodiak with the Cat motor.
I also have the BUC barke on it..similar to a jake breake. It is great for long downhills you never need to use truck or trailer brakes hardly.
turbosonic1 is offline
Old 06-03-2004 | 04:05 PM
Semper Fi's Avatar
I used to own a '99 F-250 dually PSD. It was an awesome truck. I did add the K&N airfilter, a 5' exhaust and a Diablo chip in it to wake it up alot. I wouldn't reccoment the chip now because it blew a few torque converters ($$$$) The 7.3 was/is a great motor.
Mileage was approx. 16-17mpg hwy and 12-13mpg around town (non-towing) It usually got 13mpg towing heavy loads (10,000lbs-15,000lbs) on the highway.
I usually found the best rotation for the tires would be to rotate the fronts every 5,000 miles 2x, then the third time (every 15,000) switch the outside rear with the front on the same side and continue cycle again. I never touched the inside rear tires. This used to get me 70,000 miles out of the stock tires. I was pretty happy with that.
Semper Fi is offline
Old 06-03-2004 | 04:06 PM
WickedWon
FINALLY !!!! What the hell do you care about mileage It runs for free compared to the Sonic ! Hey I'm bummed that I can't make the Spring Run, I'm not going up to the lake at all but this is THE LAST WEEKEND WITH ANYTHING BUT BOATING PLANS FOR THE SUMMER !! Have fun and we'll see ya in Huron.
JD
Old 06-03-2004 | 04:20 PM
Madcow's Avatar
JD
Aimee wants to use it for her daily driver, so I need to care a little. Hell, since I bought the Chevy thats all she wants to drive. I KNOW what kind of milage that gets
Madcow is offline
Old 06-03-2004 | 05:59 PM
Blade38's Avatar
Make sure the rear diff is ok. My last 3 were always going bad. Other that that, Great truck
Blade38 is offline
Old 06-03-2004 | 06:39 PM
Madcow's Avatar
What happens to the rear end?
Madcow is offline
Old 06-03-2004 | 08:30 PM
Jim, What ya gonna do with the Chevy dually? Is it for sale? How much $ ?
tizbad4 is offline
Old 06-04-2004 | 09:14 PM
Madcow's Avatar
If I buy the Ford I'm going to sell the Chev. It's a 2000 4dr shortbox 4X4 probably around $17,000. If anyone is interested let me know and I get you some more info.
Madcow is offline
Old 06-04-2004 | 10:12 PM
Audiofn's Avatar
Charter Member #232
I have 80,000 on my 99 and it has been OK. I just got done with rear springs and new Bilsteins at all corners. Today when I started it the trany trouble light was flashing so I have to go to the dealer to find out what is up and last weekend in Maine it was BILLOWING black smoke but I think that may have been some bad gas as after I filled up it has been ok since.
Jon
Put your best foot forward!
Audiofn is offline
