Drying the boat
Old 06-08-2004 | 02:36 PM
mr_velocity's Avatar
Default Drying the boat
How is everyone drying their boat after a wash? On Sunday nights I need to get it dry so I can put the full cover on the boat. Towels just take too long, so I was thinking about a California Water Blade. Any other options?
mr_velocity is offline
Old 06-08-2004 | 02:47 PM
vagrant's Avatar
Charter Member #37 /Moderator/Platinum Member
Default Re: Drying the boat
I use a back pack leaf blower . It works very well and dry's fast
Champagne taste on a beer Budget
C. P. B. A. Carolina Power Boat Assoc
vagrant is offline
Old 06-08-2004 | 02:55 PM
MitchStellin's Avatar
If you want it really dry you need to use towels. The flat surfaces can be done with a squeegee but they do not work so well on angles.
MitchStellin is offline
Old 06-08-2004 | 02:56 PM
glassdave's Avatar
Neno the mind boggler
a friend of mine uses the blade on his cat. its 40 feet long by 12 feet wide ( the cat . . .not the blade ). thing works pretty good. knock the big stuff off with the blade and touch up with towel
08 OPA High Points Champion
glassdave is offline
Old 06-08-2004 | 03:05 PM
Havasu Cig's Avatar
I have a water deionizer that I rent by the month. It is the same as the car lots use to keep there vehicles clean. No drying needed at all. It dries completely spot free.
Havasu Cig is offline
Old 06-08-2004 | 03:13 PM
Jonas's Avatar
i am a lazy person where do i get one of those
Jonas is offline
Old 06-08-2004 | 03:32 PM
JUSTONCE's Avatar
chamois & blade.
JUSTONCE is offline
water blade for me. towel dry small spots, then the full cover
Thunder32 is offline
Old 06-08-2004 | 03:36 PM
Sydwayz's Avatar
Forum Regulator
Adam, that is a MASSIVE boat for a two axle trailer. Holy crap!
I use the Water Blade, and the Absorber, (available at Wal-Mart in purple even). Touch up with a towel. For even easier work... I have a water blade attached to a long aluminum pole.
Sydwayz is offline
Old 06-08-2004 | 03:48 PM
Brian-
2004 Myco Trailer 12,000lbs. Trailer. 6000 lb. axles. disc brakes on both axles. 16" wheels. and fits like a glove.
If you towed it, you would love it. Myco builds a great piece.
