Ngk-ur5
Old 06-10-2004 | 01:06 PM
Default Ngk-ur5
I bought the NGK-UR5 for my 502 carb with no blowers, what should I gap these at. I have heard both .035 and .040....thanks for the info
Treatj25 is offline
Old 06-12-2004 | 02:00 AM
Default Re: Ngk-ur5
Those are a pretty cool plug for an N/A motor unless you've really upped the HP. I doubt you'll see any difference between 35 and 40.
Griff is offline
Old 06-14-2004 | 07:36 AM
Default Re: Ngk-ur5
What plugs should I be running in this motor then. It has a mild cam, alum heads, stainless marine exhaust, and 850 carb.
Treatj25 is offline
Old 06-14-2004 | 08:33 AM
Strip Poker 388's Avatar
Rob
Default Re: Ngk-ur5
On NGK plugs the lower the # the hotter.. 6-7 heat range is a norm for a peformance motor.
Most people run the ac mr45t plug .
http://www.offshoreonly.com/forums/s...&highlight=ngk
http://www.offshoreonly.com/forums/s...ad.php?t=80948
Strip Poker 388 is offline
Old 06-14-2004 | 08:42 AM
robyw1's Avatar
Default Re: Ngk-ur5
I have had less than desirable results using the NGK UR series in a turobcharged application. However this was in a car. Believe it or not I have found the best plugs for boost applications were the AC Delco. Sounds strange but true. I thought I would share this incase you ever decided to get into abnormal aspiration.
Roby
robyw1 is offline
Old 06-14-2004 | 09:57 PM
Rob
Default Re: Ngk-ur5
Roby
I always used the R series plugs they are suppose to be made[assembled] in the USA they are considered a race plug.
The ur and br plugs are a standard automotive plugand most are a projected tip.
In a blown ,nos or turbo application if your not careful it will get the tips I have melted a few on the juice
Old 06-17-2004 | 04:32 PM
Default Re: Ngk-ur5
I use NGK BR series plugs in my turbo cars...they came with them. I run up to 21psi of boost in one with no problems, key is tune and no detonation.
My boat engine, built by Innovation Marine uses NGK's V-Powers #7's in my 500hp 502ci motor and in their 600HP 540ci motor. So....the NGK works quite well for making power.
Chase910 is offline
wrinkleface
05-19-2008 10:06 PM
cigrocket
7
05-09-2008 09:47 AM
BAD-HABIT
1
06-02-2004 02:08 PM
outriggers
2
06-02-2004 09:21 AM
Tom
06-23-2003 10:20 PM
