Horizontal Tabs
Old 06-11-2004 | 09:06 AM
mr_velocity's Avatar
Default Horizontal Tabs
There was a thread a while ago, actually a picture of my boat in a thread, that started a long discussion about the way my tabs are mounted, horizontal. I was reading a review of the new Fountain Sport Cruiser in Power and Motor Yacht and found this little tid bit.
"Fountain even has a trick for mounting the trim tabs to get more leverage while reducing wetted sruface drag; placing them horizontally across the transom instead of at an angle parallel to the bottom."
Fountain isn't the only one that knows that trick.
mr_velocity is offline
Old 06-11-2004 | 10:35 AM
Phantom1's Avatar
Default Re: Horizontal Tabs
Mine aren't exactly "horizontal" but they aren't set up as an extension of the running surface either. Will Smith apparrently knew that "trick" too.
Phantom1 is offline
Old 06-11-2004 | 02:03 PM
I first saw that many years ago on the back of Velocity Race Boats...not sure if all Velocity's are set up this way or just the Race Boats. Hmmmmm. Wonder if all boats would benefit from this tab placement? Or just certain hull types?
Chase910 is offline
Old 06-11-2004 | 05:23 PM
Waterfoul's Avatar
Gone Fishin'
Every Velocity I"ve seen has them mounted horizontally. Before I mounted my tabs, I called Baja and asked them about placement. They recomended to NOT mount them horizontally. Don't know why, but I took their word for it and mounted them parallel to the bottom.
'Foul
Waterfoul is offline
Waterfoul's Avatar
Gone Fishin'
'Foul
Old 06-11-2004 | 07:38 PM
I wonder if its because Velocity, Fountain run pad bottoms where Baja is a straight Vee?
Chase910 is offline
Old 06-11-2004 | 08:07 PM
mrv8outboard's Avatar
coolrunning racing
mine are flat (horizontal). that is also good for transom lift without drag.
mrv8outboard is offline
Rage
26
04-13-2012 05:40 PM
Hot Boat
06-23-2007 08:47 AM
GEORGE YURICK
Superboat
10
04-13-2007 12:23 PM
camptappakeg69
04-13-2006 11:24 PM
envision
04-09-2002 12:11 AM
