P & D / Volbvo 280 outdrive >
Old 06-13-2004 | 09:52 AM
Default P & D / Volbvo 280 outdrive
anyone familiar with the old P & D boats with Volvo 280 outdrives? 25' with 350 SB? any info re build quality, handling, etc. boat looks like an old Pantera thanks
thedonz is offline
Old 06-13-2004 | 11:07 AM
glassdave's Avatar
Neno the mind boggler
Default Re: P & D / Volbvo 280 outdrive
dont know much about the boat but i have heard the are good solid boats and competent in ruff water as well. i have had several boats with Volvo280's on them and havehad pretty good luck wih them. they have a pretty wide cross section so the can tend to blow out after the upper 60's ( i think a nose cone can help this) i know they can handel a fair amout of power also. i know of a guy that has well over a thousand hours with a 500+ HP big block and no probs so far. it is also a dual direction drive, can run either left or right hand with the switch of a bell crank arm located under the rear cover. on a side note take a close look at the drive, when merc developed the brovo they used the 280 as a guidline to their new drive. they are very similar, so much so in fact that there is a gimbal ring availiable to put a brovo in a volvo trasom plate. i wouldnt hesitate to own another boat with the 280 atached. pretty simple drive and pretty strong as well.
08 OPA High Points Champion
glassdave is offline
Old 06-13-2004 | 11:32 AM
Scott B's Avatar
Dave,
First I have heard of the gimble ring for a Bravo.. Who makes it??
Scott B is offline
Old 06-13-2004 | 11:38 AM
mopower's Avatar
Toxic FORMULA
Originally Posted by Scott B
Dave,
Yeah , that's a suprize to me too!!
mopower is offline
Old 06-13-2004 | 06:48 PM
GD,
thanks for the info, do you know who makes the gimbal ring?
thedonz is offline
Old 06-13-2004 | 07:19 PM
glassdave's Avatar
i will do some searching but before i bought my first boat with a 280 i did a bunch of research on it. i had a thread going on another board, think it may have been hotboat. i got a bunch of info on it and someone posted some info pertaining to the gimbal ring. i will see if i can find it but it has been a while. if i remeber corectly it was a in kit form with everything for the conversion.
Old 09-25-2004 | 06:34 AM
Scott B's Avatar
Question Re: P & D / Volbvo 280 outdrive
Dave,
What did you ever find out about this???
Scott B is offline
Old 09-25-2004 | 09:21 AM
Merc makes an adapter transom plate. p/n 827691A 1, retails for $865.
bobl is offline
STUCK
Velocity
21
06-16-2007 02:44 PM
SUPER AIR
08-24-2006 06:47 AM
SUPER AIR
0
06-17-2006 03:41 PM
BajaBennett
02-19-2005 06:38 AM
Dock Holiday
10-03-2002 02:13 PM
