Mercruiser serial number lookup >
Old 06-14-2004 | 06:37 PM
Default Mercruiser serial number lookup
Anybody know of a good site for looking up Mercruiser engines serial number?
Hydrolift is offline
Old 06-14-2004 | 07:20 PM
timewarp's Avatar
Default Re: Mercruiser serial number lookup
http://www.mercurypartsexpress.com
http://www.mercruiserparts.com/
http://www.dolleroffshore.com/
timewarp is offline
Old 06-14-2004 | 07:35 PM
Thank you
Old 10-11-2009 | 06:37 PM
Can anyone tell me the year of my 4.3MPI engine..the serial # is OM651192 Thanks so much
[email protected]
pmontrone is offline
Old 10-12-2009 | 01:44 AM
[email protected]
Probably 1999 from what I can tell.
Griff is offline
Old 10-12-2009 | 02:38 AM
Based on http://www.brunswickmarineemea.com/f.../mcm_95-04.pdf I would guess it is a 2003 model year, but very close to the 2004 model year.
As I read it the serial no. for model year 2003 starts with 0M365640 for 4.3 MPI Alpha One models and 0M365680 for Bravo models.
Model year 2004 starts with 0M656797 for 4.3 MPI Alpha One models and 0M655926 for Bravo models.
Phazar454Mag is offline
Old 10-12-2009 | 12:55 PM
Default Serial Number
Thanks for your help guys....in either case I'm pleasantly surprised because I pick up the boat for $1500.00 at an auction. It had bad gas and at the moment It dosen't start..any idea what I should do from here?
If I put gas in the throttle body it will start but once the gas is burned it conks out.
Thanks again
P.J.
Old 02-07-2013 | 11:40 PM
GJA
Default Mercruiser Engine
hello i have a Mercruiser the block# VM48B01722 I am trying to find out the year of this motor thanks for your help
GJA is offline
Old 02-08-2013 | 11:50 AM
BUP
your engine serial # is VM48B01722 I would double check that and see because no Merc serial # is going to pull up being VM48B.
BUP is offline
Old 02-08-2013 | 01:22 PM
Thanks again
P.J.
If it has a mechanical fuel pump check the line from the tank to the engine. You can remove it and see if is clogged. Remember you are working in a closed environment with gas fumes so use caution- make sure your lighting is secure. Check for debris. It is possible fuel pump is inop too.
Wannabe
wannabe is offline
kaama82
3
06-28-2007 08:48 PM
duunoit
0
04-01-2007 07:54 PM
IRONMAN
5
02-10-2006 10:47 AM
Dregsz
0
06-08-2005 11:30 PM
