My engine Water Pump is weeping...should I be?
There is a stain around the weep hole, and it is weeping. Does this mean I need to replace it immediately? About how much?
Thanks,
Carl
Thanks,
Carl
Baja History
2000 29 Outlaw 2x454 mags (sold)
2000 25 Outlaw 502 (moved up to 29 OL)
1998 232 Islander 7.4 (got the 25 OL)
Tow Rig
04 Excursion EB PSD 4x4 6" lift 35's
MY PICS: http://community.webshots.com/user/skygod73
Baja History
Tow Rig
Yup it needs to be replaced. They are not so bad. Last I replaced them I got them from NAPA for I think 140 bucks or so. Labor is a very simple thing to do. Should not be a bad/expensive fix. You have to use a marine one as it has a stainless impeller.
Jon
Jon
Put your best foot forward!
Check out BoatFix.com .
Circulation pumps run 66.54 to 105.00.
Bought mine from there two years ago.
Both of mine weep just a little bit when first started then stop after warm up. They have always done this and never seemed to hurt a thing. I can only assume this is because of higher water pressure until the T-Stat opens.
I have Steps & Bubbles!
Originally Posted by BajaRunner
ive got one leaking. the only reason boats can get away with this is we have bilge pumps and an unlimited water supply
Roby
Originally Posted by robyw1
uhhh.... eventually the pressure will blow out your front seal if allowed to go on this way. been there, done that. Bilge pump-smilge pump, if your waterpump shaft seal goes then you WILL over heat. I will be in Austin in a couple of weeks. I hope I won't need to tow you.
Roby
Roby
dont worry, i plan on doing it this weekend. ive just procrastinated a little more than usual. give me a buzz when you get into austin.
Yeah I figured it was toast. I'm just trying to decide if I need to do it before we go to lake Mohave this weekend. I am just finishing replacing both drive trim indicator cables. This is the first boat I have done all the work on. Sometimes it's a PITA but it sure saves $$$. I have learned a lot thanks to my trusty service manual. The job looks pretty simple. I am doing trailer brake shoes on an axle before also. I started my spring project list a month late. Thanks all!
Carl
Carl
Baja History
Tow Rig
Baja History
Tow Rig
