Noisy 7.4 MPI fuel pump and/or regulator >
Old 06-15-2004 | 10:52 AM
Default Noisy 7.4 MPI fuel pump and/or regulator
I have what I think is a new noise, mostly noticed @ idle. It sounds like the fuel pump or regulator. The machine, (7.4 MPI), seems to run good but I worry about fuel starvation. Any ideas??
baronbob is offline
Old 06-16-2004 | 10:42 PM
Default Re: Noisy 7.4 MPI fuel pump and/or regulator
Somebody must know something about this noise!!!
baronbob is offline
Old 06-17-2004 | 08:25 AM
SteveO's Avatar
I discovered the same noise this year. Sounded like it was starving for fuel, kind of a hhhmmming sound or buzzing sound. Even when you first turn the key on this fuel pump sounds like it is dying and the other motor has a nice hum to it. Took everything apart all the way to the fuel pump. Same sound. Replaced the fuel pump. Same sound. So I bought a fuel pres. gauge and checked it comparing it to the other motor. Same pres. Ran it about 5 miles, the boat ran fine.
I think it was always there I just didn't here it.
'98 7.4MPI
SteveO is offline
Old 06-17-2004 | 11:29 AM
Thanks for your response. I have heard this sound with other fuel pumps before, without consequences. I am about to depart on a trip through the San Juan islands and will be covering about 500 miles and I don't want any surprises. It sounds like you have a twin and I am certain you thought about moving the parts one @ a time to see which part moves the sound. What fuel pressure gauge did you select and what pressures are you seeing @ idle and then under way?
baronbob is offline
Old 06-17-2004 | 01:54 PM
Pat McPherson's Avatar
My pump sounded like it was cavitating last year.
Changed the filter, check the pressure, all good.
Still noisy...
This year no noise, go figure??
Patrick
Pat McPherson is offline
Old 06-17-2004 | 06:18 PM
NEXTASEX
My fuel pump on a 99 7.4 MPI started getting noisy then failed.After it left me stranded the dealer found there was a service bulletin about this pump failing.
Old 06-18-2004 | 10:00 AM
SteveO's Avatar
Great
I bought a pres. gauge at Murray's for a GM Motor (about $40). It had a few adapters in it to connect. I can't remember the fuel pres. readings, I just remember they were both the same. 30-35psi? The gauge had some good instructions for trouble shooting the fuel system. I checked with the key on to see if it held a constant pres. then with the motors running, not while under way. Both readings were the same.
SteveO is offline
Old 06-19-2004 | 01:19 PM
Did you replace it with the same model pump? I am in the process of up grading with a procharger M-1, Do you think I should increase the pump capacity and what about the regulator?
baronbob is offline
Wobble
4
06-18-2007 01:51 PM
kennyo
0
03-30-2007 03:18 PM
tssteph
6
05-10-2005 07:04 AM
liquid asset
Baja
9
03-10-2003 10:49 AM
liquid asset
3
02-25-2003 08:20 PM
