water passage from side of block
Just installed my new water pressure gage, put it on the side of the block. I have noticed everytime I pull that plug out I always have some debris/dirt. I even had to use a pick one time to get sand out of the way to allow it to drain.
what are the chances this thing is going to clog up again, I am NOT running a sea strainer at this time. Anyone have any trouble with this set-up? Should I look into a sea strainer or install it on the manifold? Thanks
Re: water passage from side of block
Most of the time they do get clogged up again. We have started to run the water pressure off of the intake manifold at the back. Just drill tap and install a fitting and you are good to go! Never clogged again.
If you have any more questions feel free to call the shop.
Pwrbt33- John S.
Offshore Performance
410-827-0200
1-877-GOFAST1
Pwrbt33- John S.
410-827-0200
1-877-GOFAST1
You can make a dirt trap out of a tee and a couple pipe nipples and a cap. Keep the sending unit higher then the nipples with the cap the sand should settle in the nipple with the cap and not the sending unit. If that makes any sense. Hard to explain. The block is the best spot to pick up water pressure.
Mark
Mark
Mark
Mark
thanks
