Replace Stock Exhaust on 496? >
Old 06-24-2004 | 08:58 PM
bn
Default Replace Stock Exhaust on 496?
Has anyone ever replaced the stock exhaust on a 496 Mag or HO? If so, were there any hp/torque gains?
bn is offline
Old 06-25-2004 | 12:32 AM
Wink Re: Replace Stock Exhaust on 496?
Several boaters have added CMI E-top exhausts to 496 packages. Our dyno says its worth about 20HP at the Crank.
Raylar
Raylar is offline
Old 06-25-2004 | 04:45 AM
bn
Default Re: Replace Stock Exhaust on 496?
Thanks for the info!
bn is offline
Old 06-25-2004 | 07:24 AM
ccarloss's Avatar
Will the standard big block CMI's bolt up to the 496 heads or does CMI make a different header for the 496 head?
ccarloss is offline
Old 06-25-2004 | 08:16 AM
Don't waste your money. The exhaust you have is designed for that motor. You will see no performance gains,
Pure Energy is offline
Old 06-25-2004 | 09:34 AM
88Fount33's Avatar
Beak botr
I agree with Pure Energy. My $00.02 says that even if you get 20 HP at the crank, the expense is not worth gain unless your old manifolds are/or are about to start leaking. Save the bucks now and make them grow until you can (Upgrade engine, install S/C, Cam, heads, intake and carb/injection improvements.) How many of us installed headers on our old cars and without doing anything else to the engine saw an improvement, other than the "coolness factor, as... I got headers an' you don't". don't get me wrong, on the right engine Hi-Perf exhaust is a MUST.
88Fount33 is offline
Old 06-25-2004 | 08:12 PM
bn
I'll probably stick with the stock exhaust for a while.
bn is offline
SDFever
Swap Shop
0
09-16-2008 11:09 PM
Plane Silly
0
05-01-2007 07:54 PM
Corbs
7
06-22-2006 12:19 PM
betitbig
1
06-09-2006 10:46 PM
Chris288
Sunsation
49
05-13-2004 09:53 AM
