Won't engage forward/reverse >
Old 06-27-2004 | 12:40 PM
kennythebus
Default Won't engage forward/reverse
Yesterday my son was driving 95 Formula 272 w 502/BravoI w/o any problems. He tied up next to another Formula as we have done forever. When he prepared to leave, he started the engine and put the shifter in forward, but the transmission didn't engage. Same thing with reverse. He checked the cable connections on the engine block and they seemed to be shifting. I am assuming a cable somehow busted inside the lower unit. Then he called this am to tell me that it didn't appear as if the unit was lowered in the water all the way and wondered if there was a fuse or something that might be "electronically" locking out the transmission. It seems to me that there is a fuse or something related to this. Any ideas. Thanks in advance.
kenny
Old 06-28-2004 | 07:42 AM
masi242's Avatar
Default Re: Won't engage forward/reverse
Allways make sure your outdrive is down, if it is up to far the u-joints will not be able to engage the drive. This happened to me backing into a beach the other day.
Hope this helps
mark
masi242 is offline
Old 06-28-2004 | 08:08 AM
obnoxus's Avatar
Charter Member #1171
If your lucky,, cable,,, if not,,, something in the upper gear set let loose. Was he shifting at idle? If it was shifted above 1,000 RPM on accident I would lean toward damage.
The best thing to do is pull off the back cap. You can see the gear set and shift assy right there. You will lose fluid,, if its shiny, theres your answer.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
justinVIP
11
02-14-2006 02:26 PM
dap100
2
07-28-2003 04:00 PM
Mad Hatter
15
07-07-2003 02:30 PM
timucin
5
06-30-2003 02:41 PM
ST31
13
05-13-2003 04:03 PM
