525SC blower capacity >
Old 06-27-2004 | 11:26 PM
dykstra's Avatar
Talking 525SC blower capacity
Anybody know the oil capacity (ounces) of the supercharger oil for a 525SC?
dykstra is offline
Old 08-05-2005 | 04:06 PM
dykstra's Avatar
Default Re: 525SC blower capacity
ttt
dykstra is offline
Old 08-05-2005 | 06:12 PM
The Merc manual I have doesn't indicate the capacity. It says to use 90 Wt. Gear lube and to fill both the front and rear cases. Dipstick for the front, fill until it runs out the rear fill plug. Sorry I couldn't be of more help. Good luck! Lou
Lmarth is offline
Old 08-09-2005 | 01:51 AM
I don't know the exact capacities. Don't really need to since it is nearly impossible to get all the lube out of them. I just suck out as much as I can and use the fill/sight hole for the rear and add slowly in the front and check the dipsick frequently while adding small amounts.
Griff is offline
Old 08-09-2005 | 07:23 AM
dykstra's Avatar
The dipstick is kind of hard to read with the oil being so clear after a change.
dykstra is offline
Old 08-09-2005 | 11:22 AM
Yes it is. I usually just pull it out and and look for the lube in the indention on the dipstick. If I'm not sure, I lay it on a paper towel.
Griff is offline
Old 08-09-2005 | 11:56 AM
GOODT's Avatar
if I remember correctly its 6- 8 oz
GOODT is offline
Old 08-09-2005 | 04:18 PM
dykstra's Avatar
Joe, I think you are correct. Thanks again for all the responses. Dave
dykstra is offline
Old 05-11-2008 | 08:03 PM
Rambunctious's Avatar
I just asked the follwing questions in a new post, but then found this one, maybe some of you are still receiving an email alert for this post:
so where is the drain, and fil level plugs for the rear, I could not see them
and do you check the front with the dip stick judt set in without threading?
and is merc hi performance gear lube the specified lube?
thanks
Ramb
Rambunctious is offline
Old 05-11-2008 | 09:03 PM
Just posted in the other thread. I may have learned a few more things since this thread as well
Griff is offline
jeff1000man
Swap Shop
2
09-21-2008 09:46 PM
Rambunctious
7
05-12-2008 10:16 PM
Scarab3DMC
07-12-2005 11:50 AM
dykstra
7
10-18-2004 06:42 PM
mtm
17
12-07-2003 10:59 PM
