Gauges fine..alarm still sounding? >
Old 06-28-2004 | 02:12 PM
Cash Bar's Avatar
Mod Squad Enforcer
Default Gauges fine..alarm still sounding?
I went to put the boat in Sat. adn the port alarm started to sound after the motor was running for a minute. All gauges were reading fine. Checked thr trim pumps and the oil level. Oil was a little low, not much. Topped off, them tried to run it on the hose on Sun. Alarm still on non-stop. Strainers look good and the gauges all read fine.
I'm stumped?
Greg
www.gregsellswaterfront.com
Cash Bar is offline
Old 06-28-2004 | 02:33 PM
J-Bonz's Avatar
Default Re: Gauges fine..alarm still sounding?
What year engines and drive set-up?
Jack
J-Bonz is offline
Old 06-28-2004 | 03:27 PM
Krumbsnatcher's Avatar
I'm stumped?
Greg
Just a hunch did you trace all your grounding wires from your sensors (drive bottle, etc..) I am not sure, but i believe the sensors work when levels get to low they create the ground for the circuit and the buzzer goes off.
I am sure someone else with accurate information will chime in on this thread, I am going to keep an eye on it!
Krumbsnatcher is offline
Old 06-29-2004 | 06:23 AM
GLH's Avatar
GLH
Drive oil level?
GLH is offline
Old 06-29-2004 | 09:46 AM
mcollinstn's Avatar
You can still have a bad switch/sender.
With the motor running, remove the wire from all of the senders
(coolanttemp/oilpress/drivereservoir/exhausttemp(for those that have it)) and you'll find the offender.
mcollinstn is offline
Old 06-29-2004 | 11:41 AM
Strip Poker 388's Avatar
Rob
mine was a oil pressure switch. You can also make a jumped wire to test between both motors . I bought the swith at napa for 3.00.It just a low pres switch.
also what mcollinstn said
Strip Poker 388 is offline
Old 06-29-2004 | 04:12 PM
Cash Bar's Avatar
Mod Squad Enforcer
Thanks, I'll check it further.
Cash Bar is offline
Old 07-02-2004 | 09:13 AM
Start by removing the sensor wires one by one that trigger the alarm. Do not reinstall any of the wires that are removed till you find the offending sensor.
Then reinstall them 1-by-1 so as not to have more than 1 sensor that is giving you the "false" alarm.
IMHO
OPIE272 is offline
Steve H
9
06-20-2008 12:08 PM
S4Hadi
13
07-19-2007 12:53 PM
Beep Beep
03-17-2007 11:48 AM
Fast Forward
4
08-22-2004 09:13 PM
thomas1369
4
03-31-2004 11:13 AM
